-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   912E jacking point (http://forums.pelicanparts.com/porsche-912-technical-forum/1027510-912e-jacking-point.html)
DJ Connolly 04-23-2019 06:56 AM
912E jacking point
Hi All,
I'm about to put the 912E up on jack stands for a long awaited heavy C-Check (aviation term). Any suggestions for a preferred point to put the jack for the rear pair of stands? I have read the Pelican Brief blog on jacking the 911. However, just wondering if there is an optimum location for doing the same for the 12E ? Suggestions/comments.... Discuss?
DJ
Dmitry at Pelican Parts 04-23-2019 03:20 PM
Hi DJ - in addition to the tech article that you likely referenced, Jacking Up Your Car, check out the link below as well.
Jack Points
Peter Graham 04-24-2019 09:53 AM
Here's how I deal with my MY68 912 (912E shouldn't be much different):
With rear jack stands in place, I lift the front of the car using an ATV jack located either side of the tow hook/front a-arm mount reinforcement; jack stands can be located at multiple places to include the suspension cross bar, front a-arm mounts...
Peter
DJ Connolly 05-08-2019 08:13 AM
Peter and Dmitre,
Thanks for your help.
DJ
mochaSC 05-09-2019 07:40 AM
Agree with above for sure. The rear torsion bar tube is a great place to use jack stands and gives you plenty of stability for suspension work . The front crossmember is another great spot . You can place wheels and jacks in other spots for safety while you're working.
