912E jacking point
Hi All,
I'm about to put the 912E up on jack stands for a long awaited heavy C-Check (aviation term). Any suggestions for a preferred point to put the jack for the rear pair of stands? I have read the Pelican Brief blog on jacking the 911. However, just wondering if there is an optimum location for doing the same for the 12E ? Suggestions/comments.... Discuss?
DJ
Old 04-23-2019, 06:56 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hi DJ - in addition to the tech article that you likely referenced, Jacking Up Your Car, check out the link below as well.
Jack Points
Old 04-23-2019, 03:20 PM
Here's how I deal with my MY68 912 (912E shouldn't be much different):
  • Drive rear wheels onto (2x6 homemade) ramps (to provide jack clearance)
  • Lift rear of the car using laminated 3/4" plywood set on transmission carrier mounts
  • Put jack stands under inboard portion of torsion bar tube
With rear jack stands in place, I lift the front of the car using an ATV jack located either side of the tow hook/front a-arm mount reinforcement; jack stands can be located at multiple places to include the suspension cross bar, front a-arm mounts...
Peter
Old 04-24-2019, 09:53 AM
Peter and Dmitre,
Thanks for your help.
DJ
Old 05-08-2019, 08:13 AM
Agree with above for sure. The rear torsion bar tube is a great place to use jack stands and gives you plenty of stability for suspension work . The front crossmember is another great spot . You can place wheels and jacks in other spots for safety while you're working.
Old 05-09-2019, 07:40 AM
