engine lid seal
Okay, I bought an engine lid seal, it goes on the license plate panel, threaded in that channel - the seal is sorta wierd, it has a 'flap' (about 2"). does anyone know how this seal is installed? did i get the correct thing? does the flap sit flat over the rear panel? or up? i can't seem to find a photo with this.
thank you, Chuck |
It should stick up...but I haven't looked to see exactly how it mounts...
Kevin, 1969 912 1992 Firebird 1985 Eldorado(SS roof) 1992 Ranger PU 1976 Cutlass(tha beast) various others in the country for parts |
I had the same problem a few weeks ago.
I wish I had pictures to show as it would be easier than trying to describe it. The seal will slide on the licence plate panel starting at one end. If you look at the seal, there's a round edge/lip on one edge that will fit inside a little groove on the panel. It can only go one way. I used soap to get it nice and slippery, but also had to use a screwdriver to bend the lip up at quite a few places. hope this helps? Troy
Troy '89 964 C4 '83 308 GTS QV '88 928 S4 |
abit off center
Your in luck, I still have my panel off. Here is a pic of my seals, there are 2 of them.
Craig |
Craig, perfect. thanks for the photo. and thanks Kevin and Troy.
regards, Chuck
'66 Porsche 912 '69 BMW 2002 |
