extra part after rebuild
Just finished rebuilding the engine on a '69 912 and I have a part left over that I can,t remember where it goes.
It is astructural support piece, triangular, about six inches long on the long side, and I can't find any bolt holes that it matches ( embarassing aint it ?)
Also... I have a hole in the top of each head that looks like a scavenge port for the valve train. It has a rubber grommet but no fitting. Looks like a good place to drop a nut into and screw up a rocker. any idea what should go on there and where it should vent to ?
'preciate it......
RonA
Old 04-11-2003, 08:26 PM
Touque's Avatar
Ron,
Have you looked at parts obsolete as they have good diagrams?
here is one of their pages:
http://store.yahoo.com/partsobsolete/cylheadreppa.html
Also, the hole in the heads? If this was a '68 engine (you sure you have a 69 in there?), I'd say it might be the air injection port from the 'smog pump'... if it is a '69, then hopefully someone else has a better idea - any pictures of these things?
Troy
Troy
'89 964 C4
'83 308 GTS QV
'88 928 S4
Old 04-12-2003, 07:14 AM
breather tube
O.K. The digram shows the opening as a breather tube, does it just vent to the engine compartment?
RonA
Old 04-12-2003, 08:16 AM
Left head is plugged. Right head is vented to the oil fill/breather.
Per diagram on above link:
#1 is plug for left head.
#3 & #4 are the grommet and tube to attach hose on the right head.
Old 04-12-2003, 09:48 AM
Aen't you supposed to have parts left over after a rebuild? I mean thats better than not having enough parts right?
Kevin,
1969 912
1992 Firebird
1985 Eldorado(SS roof)
1992 Ranger PU
1976 Cutlass(tha beast)
various others in the country for parts
Old 04-14-2003, 07:48 AM
Duke's Avatar
Tie it to your radio antenna & use it for a wind chime-sounds great at 110mph.
Old 04-17-2003, 08:14 PM
