-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   912E Engine Tin (http://forums.pelicanparts.com/porsche-912-technical-forum/106646-912e-engine-tin.html)
Britain Smith 04-15-2003 09:36 PM
912E Engine Tin
I am in need of a set of 912E engine tin...does anyone have any suggestions or sources that I can expolit.
Thanks,
Britain
TonyB 04-16-2003 06:29 AM
Partsheaven... $175.00 for a complete set of 912E sheetmetal...
Griznant 04-16-2003 11:13 AM
If you can weld, you can basically make it from 914 sheetmetal and a slightly modified 912 bellhousing tin.
I did. :)
If you want the pretty factory stuff though, the 912E stuff will do, but you'll be paying for it.
Later,
G
COLDBASS 04-16-2003 12:19 PM
Check out Griznant's work, the man is an artist with sheet metal, IMHO his work looks better than the factory tin...
Bob
Britain Smith 04-16-2003 12:23 PM
Could you send me pics of the modified 914 sheetmetal?
Griznant 04-17-2003 03:48 AM
Bob
Thanks, but it's not that great in person.
I'm no where near a professional welder. Not bad, but not a pro by any scope. It will work, and it doesn't look too bad, but pictures are very forgiving. ;)
Thanks,
G
TonyB 04-17-2003 05:48 AM
I like Griznant's job too. Besides, there were only 2,099 912E's produced in 1976. Can't be that much factory sheetmetal out there. If you get a good look at the 912E sheetmetal, the factory did exactly what Griznant did by taking the 914 2.0 sheetmetal and doing a little cutting and welding. They did make a "custom" piece to fit between the flywheel end of the motor and the car body. My first attempt I did the same as Griznant and used the old 912 piece here bent slightly and attached to the 914 tin. Later I came across someone who needed 2.0 914 engine sheetmetal and they had the 2.0 912E sheetmetal. It was a good trade!
COLDBASS 04-17-2003 05:51 AM
Thanks,
G
You are too modest. Your work appears very functional, and well-done...:)
