Britain Smith's Avatar
912E Engine Tin
I am in need of a set of 912E engine tin...does anyone have any suggestions or sources that I can expolit.
Thanks,
Britain
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 04-15-2003, 10:36 PM
Partsheaven... $175.00 for a complete set of 912E sheetmetal...
67 912 2.0 Type 4 "Gumby"
94 968 Cabriolet
http://Gumby912.servebeer.com
Old 04-16-2003, 07:29 AM
Griznant's Avatar
If you can weld, you can basically make it from 914 sheetmetal and a slightly modified 912 bellhousing tin.
I did.
If you want the pretty factory stuff though, the 912E stuff will do, but you'll be paying for it.
Later,
G
Old 04-16-2003, 12:13 PM
COLDBASS's Avatar
Thumbs up
Check out Griznant's work, the man is an artist with sheet metal, IMHO his work looks better than the factory tin...
Bob
Old 04-16-2003, 01:19 PM
Could you send me pics of the modified 914 sheetmetal?
Old 04-16-2003, 01:23 PM
Griznant's Avatar
Bob
Thanks, but it's not that great in person.
I'm no where near a professional welder. Not bad, but not a pro by any scope. It will work, and it doesn't look too bad, but pictures are very forgiving.
Thanks,
G
Old 04-17-2003, 04:48 AM
I like Griznant's job too. Besides, there were only 2,099 912E's produced in 1976. Can't be that much factory sheetmetal out there. If you get a good look at the 912E sheetmetal, the factory did exactly what Griznant did by taking the 914 2.0 sheetmetal and doing a little cutting and welding. They did make a "custom" piece to fit between the flywheel end of the motor and the car body. My first attempt I did the same as Griznant and used the old 912 piece here bent slightly and attached to the 914 tin. Later I came across someone who needed 2.0 914 engine sheetmetal and they had the 2.0 912E sheetmetal. It was a good trade!
94 968 Cabriolet
Old 04-17-2003, 06:48 AM
COLDBASS's Avatar
Thanks,
G
You are too modest. Your work appears very functional, and well-done...
Old 04-17-2003, 06:51 AM
