Help, Porsche 912,maybe the Volkswagen clutch will be right/fit?
Guys
Maybe sombody has any experience... In my Country,the Clutch Set for a 912 is very expensive, Just in Case, maybe it matches one of the Volkswagen types? Somebody told me,that the Typ 3 size is same. But not Sure. Thx for any input. Greetings from Hungary. ![]()
Email contact:Anthonyfromza@hotmail.com Last edited by Antony Mann; 07-26-2020 at 05:12 AM.. |
********AZ has a new Sachs clutch kit that includes disc, pressure plate, throwout bearing for 65-69 912’s for $300.00 but I’m not sure about shipping to Hungary. Now, Quality speciality components has a pressure plate for a Type 1 that’s convertible to a 356/912 for $48 and free shipping. One thing you can do is take your clutch disc and have new material riveted onto it. I know I might get flamed for this but the disk material is what wears. You can reuse the throwout bearing as long as it spins. Cleanup the flywheel with some sandpaper, 400 grit. Unless the pressure plate is warped you can reuse it. This is what I did with a 914 and just replacing the disc got me another 90,000 miles.
Hi,
thx for your quick answer. Yes,Unfortunately, If the product come from State,I have need to pay 10% Customs Fee, and 27% local Tax after Invoice, Sure, plus shipping cost...Its Crazy..
Email contact:Anthonyfromza@hotmail.com |
I have heard that VW discs can be used but also that they are thinner which make them subject to slippage/less service if other parts (flywheel, pressure plate) are not original spec.
IMHO, the newer 912 4-spring clutch discs are inferior to the original six-spring discs. If cost of new is an issue, you may want to investigate getting your old disc relined with new friction material. If you are set on new, another option would be to have a friend in the States send you a disc. Peter
1968 912 SW Targa (Restoration: almost Tangerine again) 1986 951 2013 Cayenne Diesel Last edited by Peter Graham; 07-30-2020 at 03:29 AM.. |
Isn't Hungary a member of the European Common Union? I'm sure the parts you need are available in Germany, a fellow member nation. Wasn't one of the main reasons for the establishment of the Union to reduce trade and taxation barriers between member nations?
Antony, what is that color of your 912. I think I have a good clutch disc for a 912. Can you PM me your mailing address
1968 912 SW Targa (Restoration: almost Tangerine again) 1986 951 2013 Cayenne Diesel |
In Germany, all parts is expensive,like a State. The mentioned Clutch Set is almost 600 Euro!...Euro,not us dollar.(Plate,disc,bearing) Example the Bearing is 180 Euro without Tax.
Thank you for your Help, I have need the Set, The disc is not Enough. I just Wondering, because -When I bough the car- the seller gived me few extra parts,in Brand new conditions! The Main Brake Cylinder (was Brand New"NOS",but 25 years old), finaly was Garbage, because all 5 piece Gumi ring (inside) was garbage. Fortunately, the VW POLO 50 Size of brake rings was same, I bought the rebuild parts in Value 5 (five) Euro/Set.... Little bit Funy: If I looking for a Porsche,will be "gold" price, for a VW, only Few Euro/Dollars The Clutch is same situation: Brand New parts,but 25 years old....
Email contact:Anthonyfromza@hotmail.com Last edited by Antony Mann; 08-15-2020 at 08:54 AM.. |
| Tags |
| porsche 912 parts |
