356autosearch's Avatar
Send a message via Skype™ to 356autosearch
C lutch release lever
The lever that goes from the clutch cable enc is very loose.
Obviously it needs to be tight but since it goes into a small opening ijn the transmission case I have found no way to tighten it. Need a special tool?
Captain Wim
541 826 8482
Old 04-28-2021, 10:14 AM
The throw-out lever articulates on a ball with the throw-out bearing sliding along a guide tube: what you are experiencing can be normal or may indicate the lever needs a new bushing in the lever's ball pocket.
Peter
1968 912 SW Targa (Restoration: almost Tangerine again)
1986 951
2013 Cayenne Diesel
Old 04-30-2021, 06:16 AM
