Replacing front rubber bushings - of front control arm
Hi
Has any of you tried to replace the two front rubber bushings of the front control arm - in situ? What I mean is: Is is possible to replace the two front bushings without removing the control arm from the car? And if so.....how?
Regards
Old 05-01-2021, 05:55 AM
Replacing the front rubber bushingsof the front control arm (revised)
Hi
Has any of you tried to replace the front rubber bushing of the front control arm - in situ? What I mean is: Is is possible to replace front bushing of each of the two control arms without removing them from the car? And if so.....how?
Regards
Old 05-01-2021, 06:01 AM
