Refinishing Fuchs.
Can anyone point me to info for refinishing my Fuchs. Kits or instruction. anything would be helpfull.
Thanks, Howard from Vinegar Hill
Ain't never too late to have a happy childhood.
'69 912 Coupe
'74 914 1.8
Old 04-29-2003, 08:48 PM
eki912's Avatar
good advice is available at these pages.technical side.
and try searching through archives , plenty of advice there too.
e k i
Old 05-03-2003, 07:44 PM
Touque's Avatar
here you go:
Fuchs 1
Fuchs 2
Fuchs 3
Troy
'89 964 C4
'83 308 GTS QV
'88 928 S4
Old 05-04-2003, 06:31 AM
Slippery Slope Victim
NY65912's Avatar
Hi Howard, here's a pic of my Fuchs restoration which I'm doing in my spare time from working on the suspension pan project.
See photo
The flowers and the rim are masked at what I believe to be the proper dimensions. The flowers are about 3/8" exposed, (masked area), the rim is a 1/2" gap between the "wall" and the end of the rim if you hold a ruler into the wheel and let it come across the rim. I bead blasted the wheel, washed it with soap and water and will clean with metal prep prior to priming.
I bought epoxy primer that is supposed to have unreal adhesion to aluminum. I will then paint with Eastwoods satin black wheel paint and clear coat with Eastwood's satin clear. I'll keep you posted on the progress.
Best regards, Mike
MikeČ
1985 M491
Old 05-12-2003, 06:37 PM
Hoffman912's Avatar
howard,
this is a post made on another message board i frequent, about how a guy had his 914 wheels done. they look really good.
http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=9;t=000524
Harry Hoffman
68' 912 Coupe 'Fritz' burgundy red (6808) | 67' 912 Coupe 'need parts?'
912 Registry charter member #912R0195-C | Early 911S Registry member #2070
http://hoffman912.blogspot.com/
Old 05-12-2003, 08:57 PM
RETIRED
Joe Bob's Avatar
Al Reed, Orange County CA.....cheap and good.
2012 ML350 3.0 Turbo Diesel
Old 05-21-2003, 03:11 PM
