HarryDude's Avatar
Question 912E turn signal switch
Does anyone have a picture/diagram/drawing of the Light switch connections to the turn switch assembly in a 1976 912E. I have the wiring diagram but it doesn't show locations on the switch itself. Or even a schematic of the switch would help. I have a few pulled out wires and cant find there homes.. I also purchased a new turn signal switch but it also looks different (wire colors) than the one in the car. I believe the one thats in the car isn't OEM. Looks like the previous owner couldn't figure it out and gave up. Any help would be appreaciated
Old 12-02-2021, 02:42 PM
http://lonestar912.org/912%20Tech%20Data/912E%20Wiring%20Diagram.pdf
E2 is the switch, track 28
Old 12-03-2021, 07:56 AM
HarryDude's Avatar
Thanks but I have a wiring diagram. What I dont have is a picture of the switch with a pinout. I don't know what tab (electrical connection) connects to what wire.
Old 12-03-2021, 10:40 AM
WFBowen's Avatar
Like this?
Old 12-06-2021, 10:29 AM
HarryDude's Avatar
Thanks for the picture. After hours under the dash I have one side working. Looks like the other side has a wiring issue. BUT I found possibly another problem. If you look behind the gas guage in the dash I see a relay socket (empty) and then the socket and relay for the blinkers. It looks like a 3 pin relay goes into it. Does anyone know what the first relay socket goes to ??! I will try to post a picture.
Old 12-15-2021, 02:42 PM
HarryDude's Avatar
Here is a picture
Old 12-16-2021, 12:25 PM
WFBowen's Avatar
My guess it’s the seat belt buzzer relay.
Old 12-16-2021, 03:24 PM
Harry, check out this forum for 912Es only.
https://www.912bbs.org/forum/forums/912e-help.35/
Old 12-28-2021, 03:25 AM
Tags
912e , head lights switch , turn signal switch , wires electrical
