-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Need info of this mounting bracket (http://forums.pelicanparts.com/porsche-912-technical-forum/1109938-need-info-mounting-bracket.html)
florida912 01-03-2022 05:59 PM
Hello,
I have a 68 912 with a raised mounting bracket just forward of the battery tray, it is attached to floor surface. I thought it might have been for the windshield washer pump but I believe the pump mounts with grommets on a vertical surface. What is the function of this bracket? Thanks to anybody that can help me with some info.
Regards,
florida912
peter leinberge 01-04-2022 06:26 AM
Pictures are essential to receive accurate direction
Peter Graham 01-04-2022 07:15 AM
I believe you are talking about the windshield washer fluid tank bracket:
http://forums.pelicanparts.com/uploa...1641312398.jpg
florida912 01-05-2022 02:12 PM
Mounting Bracket Image
The windshield washer pump appears to align with this mounting bracket Although the pump is positioned horizonally not vertically on the bracket. Also no mounting grommets needed on this 68 912. Thanks to everyone who took the time to respond to my initial post.
Regards,
Florida912http://forums.pelicanparts.com/uploa...1641424205.jpg
CASair 01-06-2022 07:16 AM
it's for the washer reservoir.
