-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   WTB engine crossmember for my 912E (http://forums.pelicanparts.com/porsche-912-technical-forum/1128205-wtb-engine-crossmember-my-912e.html)
lrodri64 10-15-2022 10:04 PM
Hi to all
I'm looking for a 912e the engine crossmember
let me know what you have.
jess p 11-09-2022 06:04 AM
Have one made. Take a look at Thesamba.com
lrodri64 11-09-2022 04:05 PM
Jess, where in samba?
Thanks.
WFBowen 11-10-2022 11:30 AM
As Jess mentioned, your best bet is to fabricate a rear mount. The original 912e mount has gotten pretty rare. You’ll probably need to start with a mount from a late VW bus, 914 etc. which will give you the proper saddle to use factory rubber mounts. Then you can weld up something to adapt the sides to your car’s frame.
As mentioned, search the Samba for the parts. See the example in the diagram:
http://forums.pelicanparts.com/uploa...1668112197.jpg
inaminit 11-11-2022 03:54 AM
Hi Folks
I did have a crossmember for sale, but now it is pending. I will be back where it is stored in about a week, and will make up a sketch with dimensions to post here before I ship it.
jess p 11-12-2022 12:35 PM
Go here
Lnengineering.com
They sell the whole kit for $625.00
inaminit 11-20-2022 08:31 AM
912E engine mount bar drawing
If you are planning to fab a mount bar- this drawing will get you started BUT- always plan to test fit along the way.http://forums.pelicanparts.com/uploa...1668965056.jpg
lrodri64 11-20-2022 05:54 PM
Thanks for all replies...
Yes, Iam going to fabricate it using the drawing and a bus mount.
Thanks again.
darkbeer 01-03-2023 03:38 PM
Try the Porsche dismantlers in the LA area Einmalig (sp?) may have one. There are 912'E's that have been 'totaled', this I am sure of.
tperazzo 01-08-2023 09:43 PM
I have what I think is a bus mount.
It was in an accident and bent, but maybe you could use the ends or take measurements from it.
Free if you want it.
Tom
Ducky549 01-13-2023 06:12 PM
i have an extra, from a 912E...no damage...in the garage
$150 plus shipping
How do I post a picture?
I'm mostly on the 9ed12bbs.org...if you post in the wanted section of classified, that would be easier for me, since i look at it several times weekly. Here not so often
Jabate 02-11-2023 12:08 PM
LN engineering now offers a “conversion mount” for installing a Typer IV engine in a 912
But you must also use an upright cooling system
