#147 of 2096
WTB engine crossmember for my 912E
Hi to all
I'm looking for a 912e the engine crossmember let me know what you have. Thanks
#147 of 2096 |
Have one made. Take a look at Thesamba.com
#147 of 2096
Jess, where in samba?
Thanks.
#147 of 2096 |
As Jess mentioned, your best bet is to fabricate a rear mount. The original 912e mount has gotten pretty rare. You’ll probably need to start with a mount from a late VW bus, 914 etc. which will give you the proper saddle to use factory rubber mounts. Then you can weld up something to adapt the sides to your car’s frame.
As mentioned, search the Samba for the parts. See the example in the diagram:
Hi Folks
I did have a crossmember for sale, but now it is pending. I will be back where it is stored in about a week, and will make up a sketch with dimensions to post here before I ship it. |
Go here
Lnengineering.com They sell the whole kit for $625.00 |
912E engine mount bar drawing
If you are planning to fab a mount bar- this drawing will get you started BUT- always plan to test fit along the way.
#147 of 2096
Thanks for all replies...
Yes, Iam going to fabricate it using the drawing and a bus mount. Thanks again.
#147 of 2096 |
Location: the bluest city in the bluest county in the bluest state by the bluest ocean...did I mention the blue skies???
Try the Porsche dismantlers in the LA area Einmalig (sp?) may have one. There are 912'E's that have been 'totaled', this I am sure of.
Greg....PCA, 356 Registry, 912 Registry 1977 911S Targa with 3.2...1960 T-5 coupe 1968 912 coupe, that's 32 P-cars, so far... 1990 Chevy 4x4 2500 pickup (with 255K & still rockin') |
I have what I think is a bus mount.
It was in an accident and bent, but maybe you could use the ends or take measurements from it. Free if you want it. Tom
www.ahhgaragetime.com |
i have an extra, from a 912E...no damage...in the garage
$150 plus shipping How do I post a picture? I'm mostly on the 9ed12bbs.org...if you post in the wanted section of classified, that would be easier for me, since i look at it several times weekly. Here not so often Last edited by Ducky549; 01-13-2023 at 07:20 PM.. |
LN engineering now offers a “conversion mount” for installing a Typer IV engine in a 912
But you must also use an upright cooling system |
