Aluminum or Magnesium?
I have a 1969 912. My son wants to rebuild the engine and tranny but the transmission gasket set has two options, aluminum or magnesium. How do I tell which one we have? Any feedback is much Appreciated!
Old 12-07-2022, 03:50 AM
WFBowen's Avatar
Can you post some pictures? If it’s a 69 trans it’s probably magnesium. Look for a casting number on the case - 901.301.101.2R should be mag. Also, magnesium will have a grayish look while alum will be more a silver look.
Bill
Old 12-07-2022, 12:01 PM
Compare the color of your transmission to the engine. If they look the same it’s aluminum. If it looks much darker it’s mag
it's not leaking....it's just marking it's territory
Old 12-07-2022, 01:20 PM
I can’t take pictures at the moment because the tranny is under the car and the car is surrounded by stuff. I really appreciate the quick reply to my question. I will put the info to good use.
Old 12-07-2022, 07:09 PM
Clean-off a dime-size area on the trans down to clean metal. Dribble vinegar on it with a q-tip. If it fizzles and froths it is magnesium.
Old 12-09-2022, 07:58 PM
