-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   912E Question (http://forums.pelicanparts.com/porsche-912-technical-forum/120675-912e-question.html)
silver912e 07-26-2003 11:35 AM
912E Question
My 912E has a hose fitting on the left side of the fan shroud that is not connected to anything. (see Picture)
Is this supposed to be connected to something?
Thanks.
http://forums.pelicanparts.com/uploa...1059244525.jpg
COLDBASS 07-27-2003 08:19 AM
I have a nipple on the fan shroud, but it does not extend past the compressor bracket as yours does. Mine is not blocked. I'll look through the Burgundy service manual (if I can remember where I stored it) over the next few days...
I can't think of anything (923/912E related) that might require this type of air flow with that dia hose...Perhaps a 914 or other type IV app?
Bob:confused:
Also, it appears that your wiring/hoses are clear of the EGR piping.
You probaby want to check this on a regular basis. Somehow these items seem to be attracted to heat sources which naturally results in melting the sheathing, housing, etc...I check this every few days when I check oil levels...
redcar 07-27-2003 10:01 AM
I believe this should lead to the charcoal filter/cannister located on the passenger side of the firewall. It provides a source of ambient temperature air to the air flow sensor. The air flow sensor uses the temperature, as well as quantity, of air to do it's black magic.
The attached pic shows the charcoal cannister. The hose leads from the left of the cannister to the outlet shown in your pic.
http://forums.pelicanparts.com/uploa...1059325233.jpg
silver912e 07-27-2003 10:21 AM
Thanks guys. I can always count on this board as a source of good information.
Nige-912E 07-28-2003 02:35 AM
how clean are those trailing arms!!!!!!
