Question 912 Headlight question
The car is a 1969 912
I lost the right headlight, thought it had burned out.
It works fine on High beam but will not light up on low beam, so
I naturally replaced the bulb, no luck, still works in high, but not
on low. So I pulled out the Volt meter, un-plugged the lamp
and low and behold, 12v on low beam. So I plug the bulb back in
and nothing. I decide to check the voltage with the bulb plugged
in and 0 volts read on the meter.
Unplug the bulb and I get 12V. I switched bulbs with the left one
which works and still no low beam, but it works on high.... Any
ideas?? Is there a relay that could be causing this?
Let me know what you think.
lenball@sbcglobal.net
Old 09-14-2003, 11:09 AM
Maybe its the ground wire. You say 12v at low side, but where is the neg. side of the meter, car ground or the plug ground? Maybe High beam is getting ground somehow from low side. Just a thought
GoodLuck
Brett
PtCruiser 03burb 4Kids
Best 356/912 Shop I found on the East Coast:
TimBerardelli Racing 703.461.3436
Long and Gone:
610 Boss302 41coupe XKE 240z Sqback 2002 912
Old 09-14-2003, 11:18 AM
Thanks Brett,
I am checking the groud at both sources, the chassis and the plug and get the same results, 12V on the low beam ciurcut without the bulb plugged in but nothig when it is, but i will check the grounds again, could have always overlooked something...
Thanks again,
Len
Old 09-14-2003, 02:06 PM
