Engine Cherp
Hello again,
I have a strange Cherp sound coming from the engine, Not the wheels, HA HA.
When the car is idling , once in awhile you can here 1 Cherp come from the engine.
I also have 1 Oil leek coming from the Main Pulley.
Does any one know what that might be.
Regards,
Andrew.
Old 09-08-2003, 09:54 AM
Check the base of the carberators. Run your fingers around the bases and you might find a little air leak. I had this problem. Dabbed some oil resistant silicone on the gap and that solved it.
Various Porsche's
Old 09-08-2003, 11:02 AM
abit off center
cgarr's Avatar
Is it like a (sneeze) out the carb? Mine will do this if the idle adjustment is too lean or if the carbs are not in sync at idle.
Craig
______________________
Craig
G2Performance
Old 09-08-2003, 11:03 AM
Hoffman912's Avatar
if they are dell'orto's, they are known to chirp
Harry Hoffman
68' 912 Coupe 'Fritz' burgundy red (6808) | 67' 912 Coupe 'need parts?'
912 Registry charter member #912R0195-C | Early 911S Registry member #2070
http://hoffman912.blogspot.com/
Old 09-08-2003, 01:28 PM
Im new to the game, this is my first, What is a dell orto???
Old 09-08-2003, 01:49 PM
A third brand of carburetor after Solexes and Webers that will run on our 912s. Some owners are very happy with them.
Old 09-09-2003, 03:20 PM
