Question Differential Shaft Seal Replacement
Can I replace the left & right side differential shaft seals without dropping the engine & transmission?
Mine are leaking and throwing oil all over the place. I kept thinking it was the engine leaking oil but not so.
I have read only about the driver side seal replacement hopefully the passenger side is just as simple.
Thanks for your help.
Ron D
RonD 69912T
Old 09-05-2003, 08:10 AM
Ron,
I beleive it can be done without dropping the engine etc. But when i did mine I think it was a whole lot easier with the engine out.
Are the actual gaskets leaking or the dust boots? either way you might as well change them all since you are going in there.
For the 69 you have 4 bolts and 2 guide pins, you might have to pound a screwdriver between the mating surfaces to get them to seperate. No worries though as that is some very hardened steel and can take a good beating with no problems.
Craign
Old 09-05-2003, 10:48 AM
Craig:
From what I can see the oil is leaking out the output shaft seals next to the trans body and under the flanges. The oil is being flung out as the shafts rotate. The starter motor and the underbody are covered with oil in the area around the shafts.
The CV joints and boots are fine.
The oil deposits on the hot engine block and runs down the heater boxes, some gets on the exhaust headers too.
Thanks,
Ron
RonD 69912T
Old 09-05-2003, 11:18 AM
Morrie's Avatar
Hi Ron!
I just did this within the last week or so. IMHO there's no reason to pull the motor, though mine was out for other reasons.
The seal is an easy change out. there's an O ring behind the half shaft that keeps fluid out of the CV joint. Mine had also failed so I replaced it and repacked the CV joints. I bet the whole job takes you less than 2 hours.....
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe"
Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S
Old 09-06-2003, 01:42 PM
Differential Shaft Seals
Craig/Morrie:
The Porsche factory Shop Manual lists the seals as P/N 99-113-058-050 (45 x 65 x 10 mm) for the "Chilled" trans Housing.
It lists seals P/N 999-113-111-50 (45 x 68 x 10 mm) for the "Investment Cast" trans housing.
What of the two types of transmissons do we have on our 5 speed 69 912's?
What was the seal size that you used??
thanks,
Ron
RonD 69912T
Old 09-09-2003, 05:48 AM
Morrie's Avatar
Wow.. I just called Zimms and told them I had a 67 912 with a 5 speed. The seal fit...... looks like I got lucky???
Morrie
Old 09-09-2003, 06:47 AM
Morrie:
Do you know the dimensions of the seal you used??
I am surmising that the 69 912 came with either a cast aluminum transmission housing (chilled) or the magnesium (Investment Cast) transmission housing. Probably based on when in 1969 it was made.
I just don't know which one I have.
Thanks,
Ron
RonD 69912T
Old 09-09-2003, 07:15 AM
Morrie's Avatar
Will reading the Porsche PN off the side of the casing help you? Maybe someone can reference it to the correct seal. I cant say I know the size of the one I used in my 67.... due to my ignorance, I just pulled the old and pressed in the new.....
Old 09-09-2003, 08:40 AM
Stoddard's catalog lists the Side Cover Seal 45 x 65 x 10 mm for the 65-69 with aluminum case and the 45 x 68 x 10 mm for the 69-86 magnesium case. P/N's 999-113-058-50 and 999-113-183-40 respectively.
I'll just buy two each of both sizes and return the ones that don't fit.
Thanks,
Ron
RonD 69912T
Old 09-09-2003, 10:17 AM
Morrie's Avatar
once again it looks like I misunderstood. The seals I replaced are the ones around the output shafts, not the side covers..... sorry for the confusion...
Morrie
Old 09-09-2003, 10:30 AM
Ron
Sell the others on ebay !!! you might get what you paid for all, if not more. Sell the used ones TOO. Ebay's a funny thing sometimes. Buying both set WAS the right way to go.
GoodLuck
Brett
PtCruiser 03burb 4Kids
Best 356/912 Shop I found on the East Coast:
TimBerardelli Racing 703.461.3436
Long and Gone:
610 Boss302 41coupe XKE 240z Sqback 2002 912
Old 09-09-2003, 12:06 PM
Morrie:
You are right, the Porsche shop Manual & Stoddard refers to them as "Side Cover Seals". You and I call them output shaft seals. There is a side cover to the trans casting on the drivers side of the transmission. The left seal seal sits in the center of the cover and the left shaft goes thru it.
The other side of the trans does not have the side cover, the seal cavity is machined into the trans casting.
Same-same.
thanks,
Ron
RonD 69912T
Old 09-09-2003, 12:33 PM
Morrie's Avatar
gotcha.....
Old 09-09-2003, 03:00 PM
