Wanted - Hazard/Warning Flasher P/N 90161534110
Turns out my flasher was bad. Had to open mine up to get it working and would like to find a replacement. It's a bare aluminum cylindrical can about 3 inches long, with four terminals, and it's located behind the pedal board on the driver's side. P/N 90161534110.
Thanks!
Dave
Old 12-06-2003, 05:44 AM
abit off center
cgarr's Avatar
I got one that looks new if you want to try it but the numbers are a bit different, its a Hella 96pl-12V part number 90161803?00 Blinker, the tabs on the bottom say +49 C -31 49a I can send it to you if you want to try it?
Craig
______________________
Craig
G2Performance
Old 12-06-2003, 11:09 AM
Craig,
Thanks for your generous offer, but I tried one with terminals labled very similar to what you describe, and it didn't work; perhaps because I didn't have it connected properly. The pins on the original are labeled
S-, L, R, and 30. The generic one I tried is labeled 49, 49a, C2 and 31. Any idea how they correlate?
Thanks again,
Dave
Old 12-06-2003, 02:56 PM
