-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Help Needed Fast PLeAse (due to difficulty in shifting gears)!!!!! (http://forums.pelicanparts.com/porsche-912-technical-forum/140446-help-needed-fast-please-due-difficulty-shifting-gears.html)
h20_mako 12-20-2003 05:32 AM
I currently own a right-hand drive, 5-speed Porsche 912 (1969) . And i have a gear shifting difficulty. 1st gear is difficult to engage, Reverse gear lockout not working. Can engage Reverse without moving lever to the extreme top left hand. The Gearbox is fully reconditioned by Maestro. Gear Linkage has been adjusted as per workshop manual. Is it due to a Faulty Gear Lever Assembly?????
Do you have a complete set of the gear lever assembly ???
Thanks!! for your help. Please reply As Soon As Possible.
Daniel Ling(Singapore)
Nicol4 12-20-2003 09:47 AM
http://www.pelicanparts.com/techarticles/911_shifting_improvements/911_shifting_improvements.htm
Try this link.
craign 12-20-2003 04:20 PM
Have you made sure the linkage in the tunnel is set right? It almost sounds like it is off by a notch or 2.
Craig
C. Clark 12-20-2003 05:00 PM
It could need a bushing set.
Chas.
avsarinana 12-20-2003 07:01 PM
It's your clutch,it needs replacing.You say you have trouble putting it into reverse and first gear.
If you only had trouble putting it into first gear, then it may be your tranny.
Art
Jim Smolka 01-20-2004 04:02 PM
Take apart the shifter assembly. Something could be loose or broken
