a dizzy question
Just a quick one- i have a 031 distributor, is this the original equipment on a 67-68 ish engine and will a luminition kit fit? cheers.
E-MAIL ROTHKO1@EXCITE
Old 02-25-2004, 02:35 PM
Hoffman912's Avatar
031 is oem.. but not positive on which years. either way thats the best dizzy you can have for your car, over anything else new or used. if it breaks spend the money and rebuild it, as they stopped making the 031 a long long lng time ago, and there no longer make the 050 (cheep replacement distributor with enough advance for a 912 engine).
Harry Hoffman
68' 912 Coupe 'Fritz' burgundy red (6808) | 67' 912 Coupe 'need parts?'
912 Registry charter member #912R0195-C | Early 911S Registry member #2070
http://hoffman912.blogspot.com/
Old 02-25-2004, 03:24 PM
The 031 is the factory 356/912 'replacement' distributor. It was not a stock distributor on any model.
Other than that what Harry said.
Be sure you don't have too much advance. The later 031's did not have a rock solid way of limiting advance.
Old 02-26-2004, 01:20 AM
Thanks for your help, Im against using the 009 because of the advance curve so thats great! Cheers guys. Now its just loose exhaust valves and a gasket set and it will be back on the road! Is there a cheap gasket set out there?
Old 02-26-2004, 01:52 PM
Do yourself a favor and don't buy a cheap gasket set- they will leak! I have used many of the Victor Reinz gasket set fo a while now and many of the seals are just no good. Spend the dough and buy CSPs ultimate gasket set. That is if you don't want to mark your spot whereever you go.
031 is the best distributor to use, although a 050 is pretty good too, not a huge difference.
VintageExcellence.com
Old 02-28-2004, 12:17 PM
Thanks, I will look in to the better set. It makes a huge difference if you can elliminate leaks-less top ups on my way to monaco!
Old 02-29-2004, 07:46 AM
