Talking Webers (again) This time new goodies installed!
I just installed the new 32mm main venturis and 135 main jets on my 40 IDfs. Installation was easy. To install the main jets unscre the emulsion tube hoder, pop off the old jet and pop on the new jets. To replace the venturis take off the carb plate, the delivery valve and pump jet (they unscrew) pull out the secondary venturi, unscrew the bolt hodingt he main venturi in and take it out. Very simple. Unfortunately my webers are sick, not because of this, and I'm having to rebuild them, so no performace quotes, but the installation was very easy, and took less than an hour, less than a minute per main jet! Hope this helps some of you!
Also how do you adjust the floats? Thanks
Joshua Harrison
1968 912 Coupe
Old 04-18-2001, 04:36 PM
