Question poor running engine
Hi group, thanks for your previous help. Asa new 69 912 owner I have another question. I have not driven my car much in the past 2 weeks and took it out today. The engine always has run very smoothly but now the engine sounds like it does not want to idle and spits as I take off other times it sounds fine. I took it on the freeway and level it ran fine but up a hill started spurttering again. Any help would be great. Could it be fouled plug(s)?Thanks, Mark
Old 04-27-2001, 08:33 PM
Post
Most likely plugged idle jets or fouled plugs.
Joshua Harrison
1968 912 Coupe
Old 04-27-2001, 08:54 PM
Post
thanks!
Old 04-27-2001, 09:13 PM
Post
How about clogged fuel filter? Crappy old gas with stuff floating in it? Try some Heet in there, there might be water in the gas for whatever reason.
Old 05-02-2001, 10:49 AM
Post
WE were doing some other work and found out it wasa broken ring. We are also replacing the spirngs. So it sould be up and running next week. The previous owner(or who ever did his engine work) did some mickey mouse things so we are getting it right. Thanks, Mark
Old 05-02-2001, 09:33 PM
Post
We were doing some other work and found out it was a broken ring. We are also replacing the springs. So it should be up and running next week. The previous owner(or who ever did his engine work) did some mickey mouse things so we are getting it right. Thanks, Mark
