driver side window crank replacement
The window on my driver's door is not staying up anymore and has a clicking sound as it hits the top. Does anyoe know if this crank assembly is hard to replace? Thanks, Mark
Old 05-10-2001, 05:41 AM
Efrain68912's Avatar
Post
I had a similar problem in my 68. I popped the door panel off and lubricated the mechanisms in the window regulator and now I don't have the problem anymore. There is some special lubricant you are supposed to use, but I forgot what it was.
Old 05-10-2001, 05:25 PM
Post
I will try that.
thanks!
Old 05-10-2001, 06:30 PM
Post
I still beleive I need a new window regulator. If so does anyone know where I can find one and how hard is the installation? Thanks.
Old 05-10-2001, 08:30 PM
Lightbulb
If your repair of the regulator doesn't work (though I think w/ lubrication it should), I have two regulators out of my parts 67 912 -
Scott
69 912 #3078
Old 05-11-2001, 06:49 AM
Post
How much do you want for a regulator?
Old 05-13-2001, 09:52 PM
