Post Backfire
When I start my 1966 912, I get a huge backfire that sounds like a stick of dynamite. Seems to happen when the car is cold and air temperature is cool. I have rebuilt my Solexes and have MDS ignition. I also changed the exhaust manifold gasket thinking it might allow air in to ignite unburned fuel. Nothing has worked. Anyone have a suggestion?
Old 07-06-2001, 11:58 AM
Duke's Avatar
Post
The backfire may be caused by one of the following: Lean mixture.
Leaky or sticking intake valve or
a weak or broken intake valve
spring.
Bad distributor cap.
Intermittent short circuit in
primary or a short circuit in
the coil or in secondary wire
from coil to distributor. (Any of
these will cause a loud muffler
explosion.)
Hope this is of some help to you. Good luck, Duke-69/912.
Old 07-06-2001, 07:00 PM
Post
I had the same problem when I temporarily had a electric fuel pump with too much fuel pressure.
Joshua Harrison
1968 912 Coupe
www.geocities.com/jkh912
Old 07-06-2001, 07:08 PM
