-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   915/23 clutch disk question (http://forums.pelicanparts.com/porsche-912-technical-forum/156980-915-23-clutch-disk-question.html)
johncj8989 04-05-2004 10:38 AM
I am mounting a 915/23 tranny from a 912E to a 2.0 six. The 915/23 is essentially a 915 with an early 901 mainshaft. So I assume that I can get a clutch disk for a 901 and it will fit ok???
I didn't know for sure if there were any other differences in the spline that would create problems.
Can anybody clarify for me??????
david c. 04-05-2004 11:20 PM
John,
I just bought the clutch disc for use in my 912E. I'll email you the part numbers tomorrow. It's a stock Sachs clutch kit.
johncj8989 04-06-2004 07:36 AM
I knew I could depend on you Dave to help me out on this.:)
david c. 04-07-2004 05:53 PM
Here's what I got:
The clutch kit (Sachs) is KF 191-02
3151052001 is the throw out bearing (Sachs)
215mm clutch assembly
johncj8989 04-08-2004 05:26 PM
I just wonder if the 912E clutch/pressure plate will work with a flywheel off of a 67 2.0/6.
Or maybe use the 912E disk with the 911 pressure plate and flywheel.
Nobody seems to know for sure and this is my dilemma :(
david c. 04-08-2004 05:44 PM
I'll see if I can find out for you. I may know tomorrow. I'm going to pick up my newly refinished flywheel fresh from Ollie's in California. It's supposed to be in tomorrow sometime. I'll ask my mechanic who has worked on 912E's, early and old 911's etc. I know for sure that he has the charts with the cross referencing.
johncj8989 04-09-2004 06:49 AM
Thanks David!SmileWavy
TonyB 04-16-2004 08:44 AM
John,
The splines are the same, its the pilot bearing size that's different. Use your 911 flywheel with a different pilot bearing.
--Tony
67 912 2.0 Type 4 "Gumby"
http://Gumby912.servebeer.com
Jake Raby 04-18-2004 08:43 AM
The length of the input shaft is also different from the 915...
