I've traded for a pair of transaxles, and I get to choose from a selection of them. I have a '68 911 body that will be pushed by a '67 912 motor, so I want an early transaxle (901?). Questions:
1) Which transaxle do I want and how do I identify it? Where are the numbers and what do they mean? 2) How do I tell a 4-speed unit from a 5-speed? 3) Anything I should be looking for or guarding against? Thanks as always. |
Hello Enrique,
The transaxle type is stamped on the bottom of the case. Here is the information that I have from a reference book: 5 speed: 901/0, 901/02, 901/03, 901/50, 901/51(for hill climbs), 901/52, 901/53(for airport races), 901/54(nuerburgring ratrios), 902/1, 902/02, 902/50(sportomatic). 4 speed: 901/10, 902/0, 902/01, 905/00(sportomatic), 905/01(sportomatic). The book also lists the ratios, if you are interested. I don't know anything about buying a used transaxle or what to look for, sorry. If either of the transmissions are a 901 or 902, they would likely be a 65 thru 68. If one of the transaxles are a 915, it is a newer and superior unit and probably worth more money. I hope that this helps. ------------------ Adam White 68 912 Coupe |
Senior Member
Hello
Questions: 1) Which transaxle do I want and how do I identify it? Where are the numbers and what do they mean? 901 ( 911 )and 902 (912 ) tranys are very close in the ratios as the 6 just could rev far past 4 redline. But there are several types around. Check that page: http://members.rennlist.com/chuxter/901&915ratios.htm The # is on the underside on the longtitunal boss on the main housing 2) How do I tell a 4-speed unit from a 5-speed? Buy the # & shifting in 6 gears, 3 left 3 right. If one is missing its a 4. 3) Anything I should be looking for or guarding against? Hard to say without testdrive or dissasemble. I like to see dirty tranys so you can tell how they where used and how stressed they got in the case. Look for a bend shifterrod and cracks on the nose. Speeedodrive loose ? There is allways some play on the driveshaft studs but they are not really loose. Just a bit like the wheelbearings on a 912 frontaxle. Look also for the clutch forck with the guiding tube and the TOB. The guiding tube showing to much wear needs to be renewed ( or turned by 180° ) and the TOB should run free and still have the pads on the "ears" where the fork slips in. Grüsse, Roland |
Thanks for the info guys! I picked a 4 and a 5 speed. Installed the 4 speed and drove it for the first time yesterday. Seems to work quite well, though I only drove about 4 blocks (car is still mostly taken apart).
I assume the four speed shift pattern is different from the 5 in that there is no gear under reverse? Cheers. Last edited by Enrique; 11-19-2001 at 08:30 AM.. |
Hi,
Yup, no gear under reverse in the 4 speed.
Adam White Current: 1971 Alfa Romeo GT1300JR Gone but not forgotten:68 912, 76 911S, 72 911T, 1983 Audi UR Quattro |
