replacing venturis on a weber 40 idf
Does anyone know how hard it is to change venturis on this model? Also, how hard is it to get 32 mm venturis. I have carbs with 28mm and I need 32 to use with the 912 engine I have.
Old 05-05-2004, 08:54 AM
cobra-6's Avatar
It's easy, just a couple of set screws hold them in place.
Take a look at a parts diagram
Weber diagram
Old 05-06-2004, 11:28 AM
www.aircooled.net sells almost every part of the Weber carb you could ever need. Drop John Connolly a line and tell him what you have and he can even get you close on the jetting too.
67 912 2.0 Type 4 "Gumby"
94 968 Cabriolet
http://Gumby912.servebeer.com
Old 05-07-2004, 10:29 AM
