67 912 valve retainers
A few weeks ago I ordered a bunch of hardware from
parts obsolete to rebuild my 912 heads. When I was shimming the valves/springs I noticed that the retainers that I was sent were much different than the four original retainers that I had. The new retainers were about a centimeter deeper than the originals and caused the valves to be compressed very little when installed, even with a few millimeters worth of shims. These retainers obviously would not work and it was impossible to set the valve springs to the proper installed length (~41mm). I was wondering what the problem is here. Was I accidentally sent 911 valve retainers. Where else can I get valve retainers (stock). I have contacted parts obsolete but they haven't called back. thanks. |
Call Gary 503-835-2300 I talked to him yesterday.
