cobra-6's Avatar
Question Weber question and rich mix
The car's running very rich and fouling plugs. Mixture screws seem to make little difference( I'M using .50 jets) When I pulled the carb top off to check/adjust the float, I noticed the paper gasket was soaked with gas. The floats were at 9mm, instead of 10. I was wondering if the starter valves were letting fuel up and in and flooding the engine. I though they weren't supposed to work without a choke, but was wondering if I should block them or see how the adjustment of the float does.
The needle valves work fine when closed. Just seemed like too much fuel were it's not supposed to be
Old 04-04-2005, 01:05 PM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
no starter valves
Get the block off plates and disable them. Almost certainly that's your problem.
Mark Petry
Bainbridge Island, WA
Old 04-05-2005, 05:40 AM
cobra-6's Avatar
inlet valves
Thanks Mark
Another thing I've noticed is that the rebuild kit came with a .200 needle valve, the old valves were .175. Does that make a large difference?
Old 04-06-2005, 10:47 AM
