Lightbulb VW clutch alternative for 901 trans
Is there a VW clutch compatible to the 901 trans 4-speed?
Old 06-19-2005, 12:47 AM
Nige-912E's Avatar
Its a UK site, but it might help you
https://www.sachs-uk.co.uk/start.asp
choose your car from the drill down listings and once you've found it, you click a button that shows other vehicles that use the particular clutch part.
The link below is the result for my 1976 912e clutch disk
http://www.sachs-uk.co.uk/fit_list.asp?part_number=881861%20999783&desc=Torsion%20damper%20plate%20with%20organic%20r acing%20facings&type=c&title=Performance%20Clutch%20Disc
OK
Nige
Old 06-20-2005, 01:40 AM
Morrie's Avatar
I ran a 200mm VW clutch disc in my car for almost 2 years. It cost 15 bucks, fit my non-existent budget at the time. It was good for a band aide but the smaller springs and thinner wear surface didn't make it a good long term solution.
I did purchase a sachs VW clutch disc recently for around 40 bucks. This disc is much more similar to the Sachs disc for the 912. The springs are slightly smaller but appears to be the same with that exception. I did get a good deal on a complete Porsche setup, so its just collecting dust at the moment, but I would have installed that one as a final solution if I did not have the other setup.
Morrie
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe"
Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S
Old 06-23-2005, 10:07 PM
