Gasoline Sending Unit Removal
I'm embarrassed even asking this one. But, better to ask than break something ....
My gas guage is not working correctly. I suspect it's the sending unit. I know how to remove the sending unit, but I am having difficulty removing the connector from the sending unit itself. It feels permanantly fixed. Any tricks? Thanks in advance. Jeff Shropshire
Jeff Shropshire jshr@houston.rr.com |
abit off center
It should pull straight up, there is no trick to it, maybe its so corroded and thats why it wont work? Sometimes I have seen undercoating around that area that will kind of glue the things down. Just work it back and fourth with a pair of screwdrivers?
Craig
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Thank you!! I'll give it a try.
Jeff
