dimps8's Avatar
Angry stop light
problem with r/h stop lamp. replaced new 12v/21/5w globes all round.r/h lamp is dull compared to l/h. have not had the time in inspect voltage yet but probably parker lamp (5w) coming on instead of stop(21W)???
Damon Harris
Damon Harris
66 912 coupe
Old 11-12-2001, 02:10 PM
If the parking lamp comes on you should be able to tell a difference because they are not in the same place (different bulb, different location) If that the problem, its probably miss wired. Get a color wiring diagram and check the wiring. If thats not the problem check the grounds and connectors.
Old 11-13-2001, 12:53 PM
