| View Poll Results: Would the 2.0 liter vw engine bolt up to a porsche 912 transaxle? | |||
| yes |
4 | 80.00% |
| no |
0 | 0% |
| maybe |
0 | 0% |
| or hell no |
1 | 20.00% |
| Voters: 5. This poll is closed | |||
LinkBack | Thread Tools |
Would a 2.0 liter VW engine bolt up to a...
Porsche 5 speed transaxle for the 912?
Tony Nuti |
Yes, but you'll need to mess with the flywheel/clutch to make it all work nicely.
You don't need adapter plates for the crankcase to bellhousing |
Yes it will, you would want to get the flywhell that is on the 914 engine (same as the type 4 Engine), the ring gear is offset to compensate for the the 901 transmission's starter location. The bus clutch will work fine although you might consider a better clutch if money is available.
1997 911 Carrera Cabriolet 66 912, 67 912 Outlaw 65 Ac Cobra reproduction 2012 Audi A8L 1999 Ferrari 360 Modena |
