Fabricating new seat rails.
New seats for my car so need to make new rails to fit. So far so good.
Old 05-02-2007, 11:48 AM
Mew911: those brackets look like they will be suffice when your finished you could show your car to us and pour some of that home brew for the rest of us. nice seats by the way.
Old 05-02-2007, 12:02 PM
Tony???:-)
Old 05-02-2007, 08:32 PM
That looks like the highly sought after and coveted custom Mark Petry fire extinguisher mount.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 05-03-2007, 12:05 PM
That is the Limited edition Mark Petry ( signitured ) mount.
just look at that Germany craftsmanship;-)
Old 05-03-2007, 04:27 PM
Finished up the seat install today, and can't wait to take her for a cruise. Wish it would stop hailing;-(
Old 05-04-2007, 01:50 PM
Green 912's Avatar
Nice fit up work but with the seat belts fastened to the seat base you are only being held by little 8 mm bolts in a wreck. Porsche had them on the tunnel and rocker wall. Can you put them back and maintain the original safety? This setup would not pass most DE tech inspections.
Old 05-10-2007, 03:30 PM
Yeah, I thought that wouldn't fly, or as I would fly, right through the window;-) I'll work on a new plan but I simply didn't want to drill large holes through the pan.
Old 05-10-2007, 06:57 PM
However, our original seats up to 1968 mounted to the rear of each seat side. This follows the same concept and perhaps this design is too unsafe. The 69 and later has the mount in the door frame side for shoulder belt. This will come in handy to hold on to (since this would be the only part remaining within the car) while you are being propelled out the front window along with your seat;-)
Old 05-11-2007, 12:49 PM
