-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Mount Bracket for VW engine (http://forums.pelicanparts.com/porsche-912-technical-forum/382366-mount-bracket-vw-engine.html)
Val Percy 12-13-2007 09:46 PM
Hi. I just bought a 1966 912 with VW engine. It was for sale because few weeks ago the engine fixing bolts break and engine fall 10 cm (don't touch ground beaucause the dynamo touch the transverse bar and retain the engine). In fact , the system of bracket made to fix the engine looks unclever and even with new bolts, It wouldn't give good job.
Do someone have picture or scheme of good and solid mount bracket for VW engine in a 912 ?
WFBowen 12-14-2007 08:22 AM
http://www.geocities.com/clarkblumberg/911-912page9.html
Jerry1 12-24-2007 09:56 PM
Hi I have a 67 with a VW it is a pretty simple set up, its basicly a about a 6+6 plate with tube steel welded to it. I took some pictures of it maybe it will help I didn't build this it came with the car.
Hope it helpshttp://forums.pelicanparts.com/uploa...1198562136.jpg
http://forums.pelicanparts.com/uploa...1198562166.jpg
http://forums.pelicanparts.com/uploa...1198562202.jpg
Val Percy 12-25-2007 08:28 PM
thanks
Thanks for answers, links and pics
best regards
Bussmuggler 12-26-2007 07:55 AM
I recently saw a pic of a conversion on theSamba.com in the Porsche forums. A guy had a T1 VW engine mounted with the stock Bus engine hanger. He a had the engine hanger mounts welded below the engine tray on his 912. The mounting bar fit just like a stock bus would with the rubber mounts and all. By far the cleanest install of a T1 motor I have seen. It looked a lot easier that trying to fab up a new hanger bar to fit the 912 engine mount location.
