-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Different Engine support bars? (http://forums.pelicanparts.com/porsche-912-technical-forum/403971-different-engine-support-bars.html)
pksystems 04-15-2008 03:11 AM
I just want to check... I have a 1965 (I think) 912 that I picked up in boxes for cheap. Looking through all the parts, it looks like the engine support bar I have is a very thin, flat piece of metal with 2 tubes on the sides. Most of the pictures I've seen on these forums the bar looks like it's alot beefier boxed bar. Am I missing a part, or did Porsche infact upgrade this bar?
tks,
Evan
maybe368 04-15-2008 07:17 AM
That is the correct engine mount for the early 912. It bolts to the rear (front from behind) and hangs from rubber mounts on both sides...Good luck Mark
WFBowen 04-15-2008 09:17 PM
Evan:
Here are examples of the earlier vs. later style. IIRC the 69 used 6 rubber mounts.
http://forums.pelicanparts.com/uploa...1208319345.jpg
http://forums.pelicanparts.com/uploa...1208319385.jpg
fbarrett 04-30-2008 10:36 AM
Evan:
My car, 451326, built in August 1965, still has its original flat, solid mount. I don't know exactly when the softer mount came in, possibly during 1966, but I understand that it was changed to make the cars quieter.
Frank
