1982 928 us
67 with 80 engine ?alternator
will this type 4 1981 2.0L that has a 65 amp alternator work wired in with the 67 wiring .
There is no reason that it should not work. The Alternator should have it's own reg built in. So you will have to remove the Generator one from the car. As long as you figure out and connect the wires correctly there should be no problems.
1982 928 us
thanks
how to do it its not as simple as taking the v reg out of 67 there are other wires coming from it look at it and sort out and be back what wire where to |
