-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   911 head conversion -912 bottom end (http://forums.pelicanparts.com/porsche-912-technical-forum/447559-911-head-conversion-912-bottom-end.html)
micheloaks 12-21-2008 07:21 PM
Have been researching engine build options currently have a fast typ 4 underway for my 912. I recently came across a cryptic reference to 911 heads on a 912? Does anyone have knowledge of this conversion??? Or have i misread the reference. Thanks MIchel
C. Clark 12-23-2008 08:35 AM
911 is a six, 912 is a four......?
Chas.
MarKoBrow 12-23-2008 01:22 PM
There are several but all have been custom built, I have been building one myself (for 18 months now) Here are some pictures of a few that exist now. You will notice that the cam tower is cut and welded ,custom cams ect...
http://forums.pelicanparts.com/uploa...1230067235.jpg
http://forums.pelicanparts.com/uploa...1230067257.jpg
http://forums.pelicanparts.com/uploa...1230067277.jpg
MarKoBrow 12-23-2008 01:24 PM
Send me a note and I will forward you some links of forums that have threads devoted to this subject
micheloaks 12-29-2008 03:11 AM
like the craziness of it all pure porsche perverse ...send more technical build details...have these been built to show it can be done or were these built for specific track/race use? Michel
MarKoBrow 12-29-2008 10:04 AM
This a very popular conversion in Europe, the engine in these pictures is over 20 years old. I have found when inquiring about the conversion here I was met with a lot of negatives. http://centralvwaudi.com/Russ_Fellows.htm the link that I provided is a start and it chronicals on of the most known engines of this type. I think that it could be a little neater but it serves it's purpose well.
When I get home I will be able to provide more information
Jaems 12-29-2008 10:45 AM
Why bother with this conversion. You can buy the parts for a 4 cylinder 911 engine. It would be cheaper in the long run and more reliable. I forgot the name of the folks that do this. However, if you contact the folks at Parts Obsolete. They can turn you on the them. They are very good friend with this manufacture. They even have one of his
engines.http://forums.pelicanparts.com/uploa...1230576299.jpg
Flieger 12-29-2008 12:01 PM
Polopolous 4-cylinder 911 engines.
MarKoBrow 12-29-2008 02:01 PM
Cheaper in the long run? I don't know. I am waiting to get one of Deans motors for my 356 and I would not call it cheap or even inexpensive. I have spent a little over 1600US for the parts for my current overcam type4 engine project, all on ebay. Dean sent me this quote:
"The kit price is 12,995.99 dollars.
The kit consists of crankcase, crankshaft, camshafts and oil pump drive; There are two parts groups that need modification to use with a 4 cylinder 911 motor. These are the cam towers( 1978 thru 1988 ) and the oil pump ( magnesium early type , 3 bar) 30% pressure 70% scavenge."
Now, I am not saying this is not worth it but the first motor that I did with alusil jugs and custom machine cams and towers was 2300 complete and it's still runs strong. The way I figure even after I spend the 12k I still have to spend another 5K to get it on the road and this is a VERY conservative number. The turnkey engines are close to 25,000 with no special jugs or cylinders.
micheloaks 12-29-2008 10:00 PM
polopolus motors
I too would like a polopolus motor...and had Dean supply a cost for the kit and it is as Mark suggests...not an inexpensive motor once all the build issues are factored in. Nonetheless an impressive motor.
I was interested in the idea of distributing the motors in Australia, however with the current build programme (small) coupled with exchange rates makes the motor all but impractical...read $35-40,000.00 Australian Dollars....Now if we could convince Dean to upscale production????:) I am sure this motor could be a more viable, read affordable option for more people...Mark I look forward to the additional information. Has anyone actually documented (drawn) the conversion?
This would be a great thing.
Regards Michel
Jaems 12-30-2008 11:40 AM
By the time you find all the parts and machine them to fit. You wil have about as much in the 912 conversion as you would in the Dean engine. When I did my 912R engine I put about 16K into it. I bought all OEM or new parts Good quality bearings are hard, if not impossible to find. My case was standard/standard and I have forged pistons, rods, and crank. On the dyno my engine produces 114 lb of torque and 116 hp at the rear wheels. I may be off a little on the dyno test. It's been a while since I did the dyno. However, it is close and my 912R is streetable.
MarKoBrow 12-30-2008 07:43 PM
If that were the case I would have bought two of Dean's motors, I have TWO type 4 motors one complete and one I putting together now and I am have spent less than 5K. Than there is ther matter of horsepower 218hp dyno'ed when built. I am going to dyno it sometime this winter when I set it up with EFI (megasquirt). The bottom line is that this is not for everyone, and the one thing that might be pointed out here is these engines are type 4 VW engines not 356/912 engines.
Jaems 12-31-2008 11:47 AM
The VW parts are easier to find. There are a lot more type 4 engines out there than the original 912/356. Also a lot more third party manufactures that make speed parts for the type 4. That is why they are called 912 Renegades the 356's are outlaws. The difference between the Outlaw and the Renegade. The Outlaw will run a 356 or 912 engines and have cosmetic/customizing changes to the body and interior. Where the Renegade is mainly the engine change to a different type/manufacture than the original such as the suburu, VW, 911, electric motors, and etc. There can be some cosmetic changes to the Renegade, however, not extreme as the outlaws.
At 218hp it is recommended that you will need front oil coolers to keep the heat down, or rebuild the engines every twenty thousand miles. Unless you are going racing. Then you will tear down after every race.
I personally prefer to run a stock factory R engine than a third party. I feel it is more reliable and this one has been. This engine has been in my car since it was built in June of 66. This car was a special order and shipped to Danmark according to the letter that I received from the factory years ago.
MarKoBrow 12-31-2008 12:11 PM
Well I guess it boils down to symantics. Emory motorsports calls allot of it's 356's with Dean's motors and other type4 creations outlaws, I actually thought the renegade name came from adding watercooled engines...Anyway I run my current engine using a drysump configuration and I have a fender mounted oil cooler. What I was trying to say is that I personally would never use a 356/912 engine for these mods as I would prefer to preserve the integrity of the engines. They are becoming harder to find as you stated earlier. This also allows me to make my cars stock again.
Happy New Year to you and I am just glad to see that someone is on this forum once and a while
Matt Monson 12-31-2008 01:23 PM
Some of us check this forum regularly. We just don't usually have anyone to talk to. :(
Jaems 01-01-2009 01:43 PM
Emory coined the term Outlaws for the 356. Gary's father was a well known Hot Rod Customizer back in the 50's. Gary started customizing the 356 and they became Outlaws. The early imperial German Eagle is the emblem that he uses and bestowals on those 356's that make the grade to be known as a Outlaws. It is only recently that the Dean engines have been included and being used in some of the Outlaws.
Eaglehttp://forums.pelicanparts.com/uploa...1230846141.jpg
The Renegade is a termed used for 912 types only. They mainly started as engine conversion such has been all ready stated. The term has been used so as not to confused the 901 type body with the 356. The Renegade badge is the Imperial Austrian Eagle.
http://forums.pelicanparts.com/uploa...1230846179.jpg
MarKoBrow 01-02-2009 05:56 AM
So you are calling my car a renegade? OK. I was told by a 356 Racer that the outlaw series had more to do with car not being in it's stock configuration. Nice badges, very nice. Maybe you could share some pics of your 912R? It would be nice to se some of the hi-po 912's in this forum I am going to take some pics of my engines and post soon
Happy New Year
Jaems 01-02-2009 10:18 AM
The car looks like a normal 912 with the exception of underneath, interior, the rear badge and of course the engine. It has factory front and rear stabilizers and front oil cooler. All the instruments are in metric and the back seats are removed and replaced with a luggage type self. The stacks were remove from the carburetors for street driving. If you want to race it just removed the interior, add a roll bar, put the stacks back on the carbs, and tune it for the
track.http://forums.pelicanparts.com/uploa...1230920151.jpg
micheloaks 01-03-2009 01:23 AM
Jaems thanks for clarifying renegade/outlaw. is it that the 912 forum says renegade and the 356 guys say all modified cars are outlaws? will have to source a badge for my car. Great clean car by the way...do not often see such fine 912's . With your designation of an "R" motor can you explain what the specs of your car are to claim the "R" tag??
Mark as per previous emaiul more info on these conversions would be great.. my little research in OZ thus far suggests that no one has done it here.
Jaems 01-03-2009 01:38 PM
There was a whole list I had somewhere. Things like a CD box and pointless distributor, a hotter cam between 280-290 degrees. The heads were cleaner than the stock ones (ported and polished. 10:1 compression and forged lower end (pistons, rods, crank). The bore was not really increased any. A one piece intake manifold matched for the Webers. Also the jetting, stacks, and etc. was matched to the cam. I have detuned it a little for a smoother street drive. I have also changed the exhaust to a stock one for the sound problems. There is little notice of a lost power with this exhaust.
It scares 911's drivers when they look in their rear view mirror and see me right behind them. Being a SWB car I can get through the real tight corners faster than they. The low end torque and lighter car makes a big difference also. On long straights I am pretty close with them up to 80 to 90 mph. After that they start leaving me far behind. HP is only really good at upper end. The torque is king at the lower end. So a lighter car, a lot of low end torque and a short wheel base makes for a fun drive added to the special suspension.
The engine was not the only thing that made it an "R" the rest went with it. This was not a US car. It was strictly for the Euro market. The factory didn't want the "R" cars marketed in the US because of the low 911 sales, at the time. The factory was trying to convert the 356 owners to the 911. The 356 folks would of jumped at this car if it was made available. Very few were made and this particular car was originally shipped to Danmark. Over the years I have only met a couple of folks that had ever hear of the 912R and they were Europeans.
I just drive and enjoy the car. I take it to some hot rod show and they really enjoy have the car around and talking cars with me. Besides it really is a fun car to drive.
