| PCA & MCSCC Instructor |
				40 IDF mixture problem
			I have a pair of 40 IDF's on my '76 912E. I had a problem with the left carb having the rear cylinder WAY too rich and the forward cylinder a little too lean. The right carb is just fine. All jets and air correctors the same. The lean cylinder would pop through the carb, while I only get about 15 mpg. I overhauled the carbs due to this problem. It looks like the problem still is there. Anyone have any ideas? Carbs are in sync. | ||
|  01-16-2009, 12:09 PM |
| Forever a Newby |
			Check that the idle jets are not clogged, this is a common weber problem...Mark
				__________________ I can pretend with the best of them, I just cannot pretend that I am not pretending   | ||
|  01-16-2009, 03:23 PM |
			Thanks Mark. Idle jets are clear, float level is 10mm, new gaskets, etc. Rob | ||
|  01-17-2009, 05:43 AM |
| Registered |
			Jetting is a process with Webers, you could try different sizes, but I don't like mixing them up. I went up a size and turned down the mixture, that worked for me, I think I run 55 or 60's, my Webers came with 50 if memory serves.....every cylinder is an individual and has to be tuned accordingly. best of luck, Chas. 356912911 | ||
|  02-20-2009, 10:57 AM |
