Ignition miss
I have a 66 that has a new key assembly and a new starter but every once in awhile it will not turn over and I have to bump or go to rear and "hot wire it" has anyone had this issue and do you think it is a faulty wire?
66 912 sold ![]() 70 911e project 90 c4/c2 bought. tahoe life |
when these cars get old. Sometimes you need a relay to give the juice a boost.
This little thing
OK that would make sense. So are you just running a wire from the batery to the relay then from the relay to the start and using the key switch to trigger it?
Here are some threads on installing a starter relay:
http://912bbs.org/index.php?a=topic&t=29560&hl=starter+relay http://912bbs.org/index.php?a=topic&t=12868&hl=starter+relay http://912bbs.org/index.php?a=topic&t=15768&hl=starter+relay
Free will is doing what we must joyfully. Jung '68 912 Coupe '82 SC sunroof |
912 Geek
The situation is usually worst when the car/engine is hot. Before adding a relay (which I eventually did, back in 1971), make sure the connections are all clean: battery, starter, ground strap, ignition switch.
Frank 451326 |
I have gone through the conections I fear the wire's are just tired. But am not sure about trying to pull new ones. I tried the above links for how the relay is used but they come up dead.
click the link again. at bottom of the page click the "view debug info"
