-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Head light-turn indicator malfunction ? (http://forums.pelicanparts.com/porsche-912-technical-forum/484941-head-light-turn-indicator-malfunction.html)
Thumper 07-12-2009 02:52 PM
My '67 has a problem.........I know this has been discussed ad nauseum
All switch functions work....individually
High / Lo and turn signals, except when I pull the Hi beam flash with lights on
The headlights go out completely....
they also don't flash with lights off.
Relay or Switch ?
any answers....I think it is the relay......and I know if it is I'll have to find a used
old part.
Jerry1 07-12-2009 09:56 PM
My guess would be the high low bypass relay or a short in the switch. Do you have a wire diagram http://www.hillmanimages.com/912/early_912_wiring.html try this maybe you will find it.
Thumper 07-13-2009 08:14 AM
Jerry thanx for the input......
I cleaned the switch with contct cleaner no change.
Must be the relay.
ks2_motorsports 07-13-2009 09:25 AM
Sometimes the contact plates get out of alignment and you can take a little pick and adjust them...
