GUN
Head light-turn indicator malfunction ?
My '67 has a problem.........I know this has been discussed ad nauseum
All switch functions work....individually High / Lo and turn signals, except when I pull the Hi beam flash with lights on The headlights go out completely.... they also don't flash with lights off. Relay or Switch ? any answers....I think it is the relay......and I know if it is I'll have to find a used old part.
When in doubt gas it....It won't help but it ends the suspense ! |
My guess would be the high low bypass relay or a short in the switch. Do you have a wire diagram http://www.hillmanimages.com/912/early_912_wiring.html try this maybe you will find it.
Jerry McAbee 1967 912 1968 912 2002 Tundra 4x4 |
GUN
Jerry thanx for the input......
I cleaned the switch with contct cleaner no change. Must be the relay.
Sometimes the contact plates get out of alignment and you can take a little pick and adjust them...
