912e Turbo Tie-Rod mod?
I'm considering having the turbo-tie-rod mod installed in my 912e.
I'm assuming this will work in my 1976 912e? Pelican Parts.com - Turbo Tie Rod Kit Is there anything special I need to tell the alignment shop, or do they set the alignment to factory specs with this mod? Thanks for any feedback you are willing to give! |
Is there a problem? Are you doing anything else along with this mod? If not, I'd wait until you do other mods along with it, that way you only need to do it once.
PCA-Chicago Region-DE Tech Coordinator-Retired PCA-Chicago Region GingerMan DE Co-Chair-Retired 1987 Cab-under construction-Sold pending pickup 1986 911- Race/DE car-Sold |
I'm probably missing something obvious though, aren't I? Like some other mod that has to be made along with this one? Something like that? Or is this a good starting place? Thanks! |
As long as you're getting it aligned anyway, go for it. But if nothing has ever been done to the car, I would at least think about bushings along with it to help maintain the alignment.
1999 ML430 1994 Carrera C2 (sold) 1976 912E |
912E and turbo tie-rods
I installed the turbo tie-rods and bump steer kit on my 912E ( along with new front torsion bars ) and it is one of the best things I have done to that car.
Steering is tight and handeling is greatly improved , I also had it four wheel balanced and aligned immediately after the upgrades. Well worth it in my opinion - Dennis |
