blakehunt's Avatar
Question high beams are no beams
Last night I finally got my 912 running on pretty much four cylinders (I think one of the carbs has some issues)! I was working on aiming the headlights and taking periodic drives to test, when suddenly when I turned on the brights, both headlights turned off! I hadn't done anything previously but aim the headlights, so I am rather curious. The fuses were fine, but I was wondering if anyone knows anything about the high beam relay. Could it have gone bad? Or is something grounding out? Thanks for the help,
Blake
Old 11-21-2001, 08:56 AM
Morrie's Avatar
The high beam relay is located under the drivers side floorboards next to the one for the 4 way flashers. If you have a bad connection there or a faulty relay, this will cause the high beams to fail.
Old 11-22-2001, 04:21 PM
