JuiceMan's Avatar
Question How To Make 911 Brake Rotors Fit 912?
OK I need new brake rotors for my 912 on front and back. The local P-Car Guru told me they are not the same as 911 rotors and also I have looked through a few catalogs and noticed different part numbers between 912 and 911 rotors as well.
911 Rotors seem to be quite reasonable compared to 912 rotors! I want to upgrade to some Frozen Rotors or maybe a cross-drilled setup.
Is there anyway to make the 911 rotors fit? Or does anyone know where I could find some, "Performance Oriented." rotors?
Thanks,
Dustin
1969 Porsche 912 <- Sold
Old 11-19-2001, 12:10 PM
Efrain68912's Avatar
I went through a similar dilemma last year. Honestly, the 912 brakes are plenty good enough for the car. However, if you are like I am (I want the WOW factor) your best bet would be to find SC suspension to put in the car. There are plenty of cross drilled/vented/slotted rotors for the setup. I ended up getting a free set of Koni red 911S struts with the aluminum calipers and vented rotors. I plan to put the Frozen slotted rotors on the car and paint the calipers red. You could have regular 912 calipers cross-drilled, not sure about gas-slotting. While you are at it, upgrade to stainless steel lines, some better pads, maybe even a bigger master cylinder, etc.
By the way, my 912 is also silver and has a roll cage. Silver ones are the fastest.
Efrain
68 912 Coupe
Old 11-20-2001, 12:31 AM
Efrain
68 912 Coupe [/B]
In other words, you couldn't afford to paint it and so left it as bare metal, or silver as you call it. Actually, isn't that what the Germans use to do. The national color was white until they changed to silver, no paint, which was lighter hense faster. Only problem with that is sliver can tend to turn brown really quick. Not good.
Old 11-20-2001, 09:31 AM
JuiceMan's Avatar
Arrow
yea Josh I read somewhere that German racers would run their cars without paint because it was lighter. Kinda like the old argument that white is lighter than black because of less pigments therefor faster
Old 11-20-2001, 09:46 AM
Yeah, the old 550 spyders and such were actually not painted. As Colin Chapman said, "for speed, add lightness."
By the way, Josh, my car actually is silver. We did paint it. I hope you don't mind.
Efrain
68 912 Coupe
Old 11-20-2001, 12:10 PM
Efrain
68 912 Coupe
There goes your 10 second quarter mile.
Out of curiosity, was silver a factory color then? I would love to see pictures as I think its one of the prettier colors on the new Porsches.
Old 11-20-2001, 12:44 PM
JuiceMan's Avatar
Cool
Josh: You can find pictures of mine at the link below. My color is Polar Ssilver Metallic. It's a factory color on some 993s and Boxsters as well. But wasn't a factory color in 1969.
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=15833
It is like a mix between silver and gold..
Old 11-20-2001, 12:51 PM
Senior Member
Hello
This was a clever move from Alfred Neugebauer ( Witch was a testdriver & race mechanic from Porsche since his time at Austro Daimler ). They scratched the white color of a Mercedes race car to pass the curb wight technical inspection.
BTW just upgrade to 911 T or E with small calipers and ventet discs all corners including the 19mm MBC will do it.
Grüsse
Old 11-20-2001, 03:33 PM
Didn't 911E's come with the S aluminum calipers?
Efrain
68 912 Coupe
Old 11-20-2001, 04:19 PM
Send a message via ICQ to AirJose
Porsche Crest
I also have a '69, rear rotors as you know are expensive. To upgrade to other Porsche rear calipers/rotors which newer year model will fit?. Roland: You say E & T models? what year? Thanks.
Old 11-22-2001, 08:49 AM
Senior Member
Hello
They where standard on the 2,2 E even on 2,2 T Sportomatic.
On the 2,4 only in combination with the S package and/or the Boge Niveaumat schocks.
Grüsse
Old 11-22-2001, 06:10 PM
