Porsche Nut
Split shaft Solex Carburetor
Can anyone give me some advice about how to rebuild Split shaft Solex carbs? I have seen a couple of specialist that do it, but the cost is very high. I was hoping to do it my self. Are all the rebuild kits out there the same? Where do I get new floats. The kits I have seen do not appear to include that.
356 Carb Rescue will do just the machine work and provide parts for a single shaft conversion. Best money you can spend on these carbs! Then you can get the rebuild kits from Pelican and end up with an excellent set of carbs.
Porsche Nut
Can someone tell me why the factory designed the split shaft originally and if they were/are so great, why would you do the conversion to make them single? I understand the conversion process and how that works. And from what I have seen it is a big improvement. I just don't want to make a mistake and covert an original part from my 68 to something it was never intended to be and then regret it. Thanks
The split shaft carbs have a better circuit design. The split shaft was done to tune each barrel but the rubber isolator wears and they fall out of tune, this part is available from ******** but it still a bit of a pain. 99% of the free world will not be able to tell if you have converted to solid shaft, if you have a big bore kit they can also be opened up to 42mm at the same time :-)
Porsche Nut
The engine was rebuilt before being parked with Mahle P&C and supposedly a brand new crank. So it sounds like I need to go ahead and send the carbs off to 356 Carb Rescue if I ever want the thing to run worth a crap?
the split shaft was introduced when USA smog controls became more stringent
Rick Becker 912 owner since 1977 PCA 912 & 912E Register Advocate, 912 Registry Member #0001 http://912register.pca.org | www.facebook.com/PCA912Register | Twitter: @PCA912Register |
Porsche Nut
I got the carbs off the car. Talked to Will at C*P and he agreed, just rebuild them. They look to be in very good condition. Yes, from what I read, the splits were introduce in 68 for smog issues. But the only thing I have seen as a reason was that they supposedly allowed better/finer tuning of the carbs, which makes them more complicated, but better when they are dialed in. I will post a pic later.
I have never understood why the bad rap on split shafts or why convert them to solid. The only real issue is maintaining the block between the shafts. That is what, a once every 15-20 year issue that is an easy fix with a piece of cut fuel line? The advantages way offset the disadvantages.
Free will is doing what we must joyfully. Jung '68 912 Coupe '82 SC sunroof |
Porsche Nut
The buffer block for split shaft carburetors are still available, part # 692-100-993-01, 2 req'd, Fits Solex 40PII-4, $2 each
You might want to check out the "Synchrometer" to best adjust them
