Rear engine bracket for VW swap
Greetings fellow enthusiast. Although somewhat of a purist, my good friend and I are currently in process of swapping a Porsche 912 engine for a VW. Many of the postings herewithin have proven exceptionally valuable in this endeavor. We are now seeking the thoughts of you, the experts, for the rear engine mount. What do you suggest/advise for the rear engine mount for this swap? Is there a simple, not so painful way to mount the VW to our 912?
All your help is greatly appreciated and will continue to be so. Thanks, |
Type I or Type IV engine?
Efrain 68 912 Coupe |
Type 1. 3 mounting holes in the lower case, go around the oil pump.
I've got just what you need in my garage..I'll take digital pics of everything and post them here tomorrow.
Meanwhile, there's quite a few pics on my website...
Clay McGuill '66 912 My 912's restoration website, '97 Jeep Cherokee, '70 Ford Bronco My Bronco's rebuild site |
Mr. Mcguill, you continue to be an inspiration for our ongoing project. Your information and pics will be greatly appreciated and put to use. Thanks.
As promised...
I tried and tried to get the images to dislay here in the forum, but geocities just doesn't remotely host graphics files well (if at all)...SO, I simply created a new page on my website with all the pics on it. Simply click on the link below and wait for the images to load (most are thumbnails, so it shouldn't take too long). I'll work on making the the thumbnails act as hyperlinks to full-size images tomorrow... http://www.geocities.com/the912guy/Enginemounts.html
Clay McGuill '66 912 My 912's restoration website, '97 Jeep Cherokee, '70 Ford Bronco My Bronco's rebuild site Last edited by ClayMcguill; 12-10-2001 at 09:34 PM.. |
AWSOME Mr. Mcguill, cant say it enough.
How many inches apart is the back plate that attaches to the engine to the front plate that attaches to the original cross member. This will allow me to figure out the length and angle of the plate that connects them both. Also, what is the measurement from the original bottom holes of the crossmember to the top two holes of the VW engine? I think that with those two figures we should be able to duplicate this bracket design. Thanks Mr. Mcguill. |
The measurement from the lower (as installed) vertical plate that bolts directly to the VW case to the upper rear vertical plate that bolts to the transverse crosssmember is exactly 3 inches.
The sides of the bracket are paralellograms, with the long sides exactly 4 inches long, and are cut at 45 degrees to the vertical plates. The distance from the crossmember mounting holes to the upper case mounting holes is 4 5/8" center-to-center. The bracket is constructed of 3/16" thick steel plate. (And the name's Clay...whenever somebody says "Mr McGuill", I figure they're either talking to my Dad..or I'm in trouble.
Clay McGuill '66 912 My 912's restoration website, '97 Jeep Cherokee, '70 Ford Bronco My Bronco's rebuild site Last edited by ClayMcguill; 12-11-2001 at 08:00 PM.. |
Great Clay, sorry about the "Mr.", just showing the due respect. The engine is a highly tweeked 1679cc.
Where did you get that engine? Or did you build it yourself? Reason being is that looks just like one of the engines at CB Performance.
Its right out of the oven. New and completely HiPo. Zero miles, were hoping it will configure nicely with the trany gearing and overall handling.
I hope you fare well on the 17th with the 66. |
Hey Geo1
WOW, great looking motor !!! As for the bracket, I thing I would try making the plate that meets the crossmember, match the factory crossmember holes. Maybe even try to use the rubber bumpers like on 68 69. Just my $0.02 Good luck Brett |
Geo: What a great looking motor. When you get some time, please post some specifics, especially what horsepower output you estimate. Looks like a great project, especially with the price of 912 motor pieces going up.
Thks & Rgds,Thanks for the replies friends! I will definitely post some spec's on this thing once my teacher and I can tear away from the shop long enough. Of particular fun right now is deciding on the bracket design. I am leaning towards a tubular steel, my sensai is talking about a single piece steel plate. We are still figuring that out but with the dimensional specs we got from Clay, we should fare well with whatever we go with.
More to come. |
