912E931
Question Why is my exhaust smoking on hills?
I am hoping someone can point me in the right direction. I am getting my 1976 912E back on the road after sitting for a time. I am noticing that it will blow white smoke once it is warmed up. This only seems to happen when I am going down hills. Anybody know what would cause it to smoke only under these circumstances? It is fine around town at all speeds until I hit a hill.
Old 06-13-2010, 09:50 AM
Max Sluiter
Flieger's Avatar
So you are engine braking when going downhill? If you accelerate, does the smoke stop? If so, that sounds like worn valve guides.
Old 06-13-2010, 10:46 AM
C. Clark's Avatar
Worn valve guides is the most obvious answer, that said excessive oil in the crankcase can also cause white smoke. Since you're noticing this in out of level situations I would look into that first. Try running a little under the full line and see what happens.
One of the worse things for a vehicle is being idle, seals dry out, gaskets fail, all kinds of bad stuff.
Best of luck,
Chas.
356912911
Old 06-13-2010, 12:55 PM
912E931
Thanks for the insight. I will start checking these out.
Old 06-13-2010, 10:53 PM
